Used Cast Iron Radiators
Old 01-03-07, 08:07 AM
Who's Avatar
Who
Who is offline
Received 2 Upvotes on 1 Post
I want to add one or two cast iron rads to my home.
I'm all fin-tube right now, and about to do some radiant but I would like to add a few cast iron rads to the basement for comfort.
What does one look for in used rads? I know to look for ones that were used for hot water systems but outside of that and knowing they are crazy heavy from lifting a few, what else should I be looking at?
Old 01-03-07, 04:06 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Cast iron rads
Obviously you would want to get one of the correct size. Before buying, ask the seller if you can pressure test it. Pressurize to 40-50 psi with air & spray it down with soapy water or let the pressure test sit over night. Try to avoid rads with obvious numerous coats of paint. The good dealers will strip & prime them.
Old 01-03-07, 04:12 PM
Who's Avatar
Who
Who is offline
Grady...
How do I hook a bike pump to it?
Old 01-03-07, 04:43 PM
Grady's Avatar
Pressure testing rads
You will need to plug the large pipe connections & install a schrader in the bleeder port. The schraders are available at any HVAC or plumbing supply house.
Old 01-03-07, 05:09 PM
Who's Avatar
Who
Who is offline
Cool!
I'll look for one on my next junket! Thanks Grady!!
