Room is too hot!! baseboard heat
hi all,
my second floor is one zone, forced hot water baseboard heat.
we have a small room that gets too hot.
I think the problem is there is too much linear feet of baseboard heat for such a small room.
any suggestions?
can i cut off some of the radiator fins? (can you even do that without trashing the piping?)
can i insulate some of the radiator fins?
thanks in advance
any suggestions?
thanks in advance
Hi all, thanks for the replies
yes, i closed down all the louvers, it didn't really help much.
the room has always been warmer, but it was a seldomly used (so we did nothing about it), but now it's used on a daily basis
i had a good look at the fins, no way to remove them without trashing the whole thing
I wrapped a portion of the fins using Pipe wrap insulation tape.
it's foil backed, 1/8 foam by 2" wide insulation tape (think fat foamy spongy duct tape)
i laid a long strip of the tape down along the top of the fins and another along the front of the fins.
i taped the "seam" between the two strips of tape using foil tape.
couldn't really wrap around the whole fins/pipe, but it did seem to make a difference
maybe i'll try to get the full wrap with aluminum foil too
thanks again
thanks again
Foamy doesn't sound good... well it sounds like it could stink in the future. The key thing with fin-tube to remember is it works by convection. If air can't flow up through the fins, the heating capacity is greatly impaired. That's all you really want to do here is stop the air. The foil will also reduce the small radiant factor of the tubing as well.
I'd just use straight foil and minimal foil tape to keep it on ...
Man I wish I would have thought of the foil.
Grady rocks!
Grady rocks!
One caveat...
Depends on what you mean by hot water pipes. If its domestic hot tap water then the temps are generally 140 and less. Water used for heating can top out at 180-200.
Received 39 Upvotes
Foil
Who:
I wish I could take credit for thinking of the foil but I can't. I learned that trick back when I was a greenhorn from a guy I called "the old fart", now that title is mine & I try to pass along such tidbits to the next generation.
Hope you don't mind me calling you that from now on! (JK) Is it possible that this room is the first room on the loop and the check valve is leaking by, causing gravity feeding into this room when there is no need for heat? Where is the thermostat located? Do you have a triple aquastat and/or tankless coil? Does the room get heat in the summer when nothing is calling? How old is the system? What type of boiler do you have? If you are able, we like seeing pic's (of the boiler).
I have the opposite problem. to little heat
I have a Santa Fin baseboards. One room has a 20 foot run but only 5 feet has fins. The room is always cold. Where can I get more snap on fins so I do not have to break the existing lines and add new sections with fins?
