replacement boiler
Old 01-20-07, 07:06 AM
T
Question replacement boiler
Hi there, I'm new to all this and I'm looking for some good advice. I'm looking to replace an older oil fired steam boiler~30 y.o. I have gotten quotes from 3 local companies all with different products:
Penco # 160-4 HSD (112,500) BTU input gas steam boiler
Weil McLain gas PEG50SPDNS
Weil McLain oil PSG04
Lennox GSB8 E/S
How do these boilers compare to each other? Any have more problematic issues over time, etc?
Other info you might want:
91 yo house, capital region of NY, 7 radiators(some with adj. valves).
Thanks for any help.
Old 01-20-07, 07:50 AM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
The first question to ask is:
Did they do an ACCURATE heat loss calculation on the home ?
I don't mean just walk through and glance around and say "Oh, 110,000 oughta do it" ...
Yer gonna live with that system (hopefully) for a long time, why take the chance that it's oversized ?
My choices would be Buderus or Burnham .
Old 01-20-07, 11:01 AM
T
How do I get the heat loss calc? One guy looked around to see the radiators, but did not actually measure. I have 7 cast iron radiators;
(in inches) (# tubes)
23*16*4 10
32*24*8 16
40*17*4.5 26
40*17*5.5 26
42*17*4.5 28
42*17*4.5 28
48*17*4.5 32
I think all are column type ~ 1 inch diameter. Living space ~1300 sq ft, 2 story house. Any other needed to know?
Old 01-20-07, 11:15 AM
Grady's Avatar
Received 41 Upvotes on 39 Posts
New steam boiler
I don't think Buderus makes steam boilers. The Burnham Mega-Steam has so far gotten very good reviews.
Before even thinking about a particular boiler you need to get an accurate heat loss calculation done. Slant Fin has a good, free program on their web site. Once that is done, the capacity of the existing radiation has to be calculated & compared to the heat loss. If you don't plan on renovating the radiation, the heat loss can be skipped & the new boiler matched to the existing radiators. This is something peculiar to steam. Dan Holohan has an excellent book on old radiators called "E.D.R." available here: http://www.heatinghelp.com/shopcart/product.cfm?category=2-59
