Oil Burner won't start up - no pressure
Old 01-23-07, 07:21 AM
T
Red face Oil Burner won't start up - no pressure
Help ... I let my heating oil tank run to empty and when the guy came to fill it up with fuel a few days ago (he filled it to 1/4 tank), he told me that he need to prime the burner, too. When he left here, my heat was running cozily... within 2 or 3 hours, the burner never went back on again ... I readjusted the thermostat a few times and that's when I realized to look down in the basement at the burner itself. Here's what I found:
1) No pressure or temperature on the gauges of the fuel pump (I assume its the fuel pump)
2) I hit that little red button to on the burner - and I hear something start - for a few seconds --- but the actual heat never comes on.
I've tried searching the forum on the method of bleeding the fuel line - but I can't find it ... I think this is what I need to do...
Help - we have a deep freeze coming soon and I want to try to fix this myself before I have to call a service guy out....
Any help or direction would be greatly appreciated!
Thanks!
- Theresa
Old 01-23-07, 02:28 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
No heat
Before we go into the burner part, I need to know if this is hot water, steam, or warm air heat. If it is hot water, we need to address the pressure issue first.
Old 01-23-07, 02:36 PM
T
Grady, thanks for your help!!
This is hot water radiator baseboard heat.
Old 01-23-07, 04:21 PM
Grady's Avatar
Hot Water Boiler
If you can post some pictures of the boiler & nearby piping it would be a big help. You can post them on photobucket or similar site & provide a link to them here.
----------------------------------------------------------------------------Since we are dealing with a boiler, I'm moving this thread to the boilers forum.
__________________________________________________________________
