radiator fins
radiator fins
i have too much heat coming from the radiator in my bedroom. i was told that if i remove some of the fins, it will reduce some of the heat. is this true and is this okay to do?
If it is finned copper, a much better, safer, and easier alternative is to fold up aluminum foil in a width that matches the fins and lay it on top of the fins. Just pop off the front cover and slip it in on top. The heat output after the airflow is stopped is about the same as straight copper. And if you need a little more heat , you can always remove some foil. Unlike the unreversible process of removing fins.
Ken
Ken
as i stated, this is a radiator. not a baseboard. i did the foil thing. still too hot. so once again... i was told that if i remove some of the fins, it will reduce some of the heat. is this true and is this okay to do? thanks.
In that case, the answer is no.
If you are asking if you can remove some of the sections in the radiator, you will ruin the radiator if you try. It should have a valve on it. Can you adjust the heat with that? If not and appearance is not crucial, yuo can still cover it with a blanket to experiment and then make a cover from wood that encloses part of the radiator. The best solution for a radiator that is ALWAYS too hot is to install a thermostatic valve in place of the hand valve there now. Then you can set it and forget it.
Ken
Ken
