Adjust Pressure on Watts Feed Line Valve
I have a Watts Regulator feed line valve with the quick feed lever leading to my gas fired boiler. (looks like this: http://www.watts.com/pdf/ES-1156F.pdf) I would like to adjust the pressure in the boiler upwards slightly (now at 12-14 psi cold, and water is not getting to the radiators on the third story of my house).
I have searched and found threads stating to loosen the lock nut and tighten the screw one turn. Where do I find this locknut and screw? The lever on the top of the valve is attached to a nut. I can remove that whole lever assembly and the rod it pushes down on when lifted to activate water flow. That exposes a hole leading down into the body of the valve. What do I do next?
Received 38 Upvotes
After removing the handle assembly you loosen the locknut at the bottom of the threaded stem that holds the handle assembly. Then turn the threaded stem clockwise (no more than 1/2 turn at a time) until you reach your desired pressure. If you cannot turn the stem by hand you may remove the pin and use a big screwdriver in the slot on top.
Remember to wait for several minutes after each 1/2 turn to be sure the valve completely reseats. When you are done, tighten the locknut without moving the stem and replace the pin (if removed) and then the handle assembly.
I think your handle assembly is removing the adjusting screw along with it. The handle assembly should be hollow with a female thread, and leave the brass male threaded screw with a slot sticking out of the top of the valve.
Yes, that is exactly what is happening. Sounds like I need to free up the handle assembly from the adjusting screw. Thanks for all the advice.
Now off to replace my expansion tank, as I've discovered that my 12-14 psi cold pressure shoots to 30 psi when hot.
