Aquastat Protecto relay will not trip. No heat!
Old 02-11-07, 06:01 AM
R
Unhappy Aquastat Protecto relay will not trip. No heat!
I have an old Peerless oil fired furnace. The system is hot water. It has a Honeywell Type R8182D Aquastat Proteto relay.
The limits are set at 180 and 160 with a 15 diff.
Here is what is happening.
When water reaches 180 the circulator comes on. When the water cools to 160 the furnace does not fire.
If I physically tap the protecto relay box, push the rest, or tap on the top silver relay it will trip and the furnace comes on.
Is there a way to reset the relay so that it will trip on its own? I'm running up and down the stair today.
Renirichory
Old 02-11-07, 08:04 AM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
Replace the control.
Old 02-11-07, 09:00 AM
R
Talking
Is the control one part of the R8182d or do you mean the whole thing?
thanks
Renrichory
Old 02-11-07, 09:21 AM
NJT's Avatar
NJT
NJT is offline
You need to replace the whole 8182 ... they aren't (well, they shouldn't) be repaired. If it's intermittent, just replace the whole thing.
Old 02-11-07, 09:35 AM
R
Lightbulb
Thanks,
Just one last question. I found the install instructions online. By replacement does it mean shutting and draining the system ...inserting a new sensing bulb in the imersion well and applying heat conducting compound?
I may not be that savy...having never done that before.
I have installed a new circulator and flow control valve with success and feel confident with wiring.
But... If I can just remove the controller on the front and connect it to the existing sensing bulb that would be great! I assume that I would not have to cool and drain the system?
Thanks again,
Renrichory
Old 02-11-07, 10:10 AM
Control
The immersion well remains on the boiler, there is NO NEED to drain the system. The sensor bulb is inserted into the well using a heat conductive compound. The sensor must be inserted properly for the control to work.
Old 02-11-07, 10:35 AM
NJT's Avatar
NJT
NJT is offline
Right... it's really not that difficult, BUT if you feel ANY apprehension about doing the job it certainly is better to call in a tech. ESPECIALLY since this is a heating system and it is the middle of February.
Old 02-11-07, 10:43 AM
Exclamation safety limit
As an added caveat, this is a MAJOR safety control. High end temperature limit, burner control, etc. It is vital to ensure that all of the limits and sensors are working properly: high limit, cad cell detection, etc. You could conceivable end up with a run away boiler or a combustion chamber full of oil if the new control is defective or not installed correctly.
Old 02-11-07, 07:01 PM
F
The mechanical relays that Honeywell uses in these controls are notorious for failing. Repair is not an option since repair voids the original UL listing.
I prefer a separate aquastat and flame safegaurd control.
Old 02-12-07, 06:25 PM
Grady's Avatar
Received 39 Upvotes on 37 Posts
Agreed
It would not cost much more, if any, to install separate aquastat & flame safety controls. Another added benefit is replacement cost should one component fail. A good combination, without getting elaborate, would be an L7224 aquastat & an R7184A primary control.
Old 02-16-07, 05:03 AM
R
Smile
thanks! maybe that is the way i will go.
Will have repair made today! yay! Heat!
Renrichory
