Beckett AFG not firing up
Old 02-12-07, 02:07 PM
For a couple days my AFG was having a hard time firing up. Now it wont fire at all. I get a little puff of smoke and thats it. It has a new pump so I dont think its that. What should be my next step in fixing it myself? Thanks in advance
Old 02-12-07, 02:28 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
New nozzle?? New Oil filter. Check transformer. set and clean electrodes.
Old 02-12-07, 02:32 PM
I found a new nozzle but its a little different. Why is there differnet nozzles? I set the electrodes as good as I could one of them is kind of rounded its not as pointed as the other one. Perhaps that could be it. Would it be a good idea to get new ones?
Old 02-12-07, 02:40 PM
Ed Imeduc's Avatar
Wink
Nozzle has to be the same IF IT WAS THE RIGHT ONE. Is the transformer good ???Test it.
Might go http://www.freepoolheat.com/oil.html
Electrodes have to be set right. Are they good ???
Old 02-12-07, 02:48 PM
One of the electrodes looks questionable by my best guess. Is the transformer the same thing as the controls?
Old 02-12-07, 02:56 PM
Ed Imeduc's Avatar
Wink
No the transformer is there for thespark to light it. Now that is 10,000V . So know what you are doing. You better call a tech to check and set the burner up for you
Old 02-12-07, 03:12 PM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
Yeah, time to call a tech...
Don't fool with 10,000 volts if you don't know what you are doing!
When was the last time this system was looked at by a tech ?
When was the last time the oil filter was changed ?
Old 02-12-07, 03:58 PM
wouldnt cutting off the power to the furnace cut off the power to the transformer?
Old 02-12-07, 04:58 PM
NJT's Avatar
NJT
NJT is offline
Yes, but what's your point?
Old 02-13-07, 07:01 AM
Whats yours?
Old 02-13-07, 02:50 PM
NJT's Avatar
NJT
NJT is offline
What I meant was, what is the point of cutting off power ?
How can you test a device if the power is cut off ?
Old 02-13-07, 03:36 PM
I got her running good. I took it apart and cleaned everything good and reset the electrodes they were a little off. It didnt start the first two times yesterday but today I tried it again and it fired right up and has been running better than ever so far. Im gonna replace the nozzle this week. thanks
