refill water, restart boiler
I don't have any experience with boilers. I'm new to a multi-family building and my neighbor says I let the water go too low; apparently the LWCO worked and shut the boiler off. My neighbor showed me the valves to refill the water but being a novice and in a dark basement could not see the glass gauge clearly. Instead of filling the gauge to halfway mark, I overfilled, to the point that water came out of two radiators for about 3-4 minutes. It was not a flood but I needed a few towels to mop it up.
My questions:
1. Now that excess water drained via my radiators, is there any danger to the overfilling? I've used a flashlight and can see the glass gauge is completely full. Will any other excess burn off as steam?
2. How do I get the boiler to restart? It's certainly cold enough in my apartment and the thermostat is on. Is there a reset button I need to push? Thank you in advance for any advice.
My questions:
Received 39 Upvotes
Flooded Steam Boiler
Do not attempt to restart the boiler until you have the water at the proper level. To do so could result in serious damage.
With this being a mult-family dwelling, there is most likely a manual reset somewhere. Without knowing more about the controls on the boiler, that is about all I can tell you.
