HydroTherm HC-100 Gas boiler Thermocoupler?
Old 03-07-07, 04:55 AM
C
Just wondering what replacement thermocoupler part is recommended for this boiler. The current thermocoupler is a Honeywell Q313A1188 which doesn't stay in place and slips down. A wire is used to hold it in place. Any help would be much appreciated.
Thanks
Old 03-07-07, 05:55 PM
Grady's Avatar
Received 39 Upvotes on 37 Posts
Thermocouple
You can get "universal" thermocouples at nearly any home center. The inside of the bottom of your thermocouple holder is probably threaded & needs the inverted nut which comes with most thermocouples to keep the thermocouple from slipping down. Another possibility is the conical clip which slips over the thermocouple was not installed.
