Can you add a radiator in the basement with a one pipe steam system?
Hi guys,
We have a one pipe steam boiler system in our house located in the basement. In the winter, it gets really cold down here so we are forced to use an electric heater which just eats up electricity. The pipes from the boiler run long the ceiling of our basement, but they are insulated and covered with wood because the basement is finished and some pipes running around the ceiling would just look bad.
My question is: is there any way to add a radiator of some sort down here. or is it impossible because the radiator would have to be located higher than the boiler? I am pretty sure that exposing the pipes in the basement would be a bad idea - the pipes are insulated for a reason. Any thoughts on this?
Received 39 Upvotes
Heat in basement
The most practical way to do this is to run a hot water loop off of the steam boiler. If you do not get your domestic hot water from the boiler, it is likely some controls would have to be changed or added. Here is a thread on exactly that subject:
http://forum.doityourself.com/showthread.php?t=298336
