zone valve installation
I want to feed a new loop on my hot water heating system. This will be 16' of baseboard in the celler. I presently have 4 zones in the house now, each with its own circulater. One zone for hot water, one for the 2nd floor, and two on the 1st floor. Instead of installing a fifth circulator, I would like to put zone valves in one of the downstairs zones. I am not sure if I can put the zone valves on the return side or do they have to be on the feed side. Could you show me a typical zone valve installation that will answer this question.
Thank You
mesantor
Thank You
mesantor
Returns tend to be the preferred location. What kind of velocity could you see going through this cellar zone if it is the only zone valve that is open for this circulator? That's something that should be calculated.
Why not just add a small pump for this zone as well? Cheaper than 2 zones valves and may save you messing the balance on an existing zone.
zone vale installation
Thank you for your reply answering my question on what side of the aystem to put the zone valves. I might just take your advice and add another pump instead.
Thanks again
mesantor
Thanks again
mesantor
Zones vs pumps
Modern pumps and zones valves will tolerate either side of the boiler. Taco, Grundfos and others manufacuter multi-speed pumps.
Last edited by twelvepole; 08-09-07 at 01:51 PM. Reason: Company name and state edited
Wouldn't a zone valve on the return side lead to migration in the piping? I have always been told to prevent migration install a positive shutoff zone valve on the supply side. Just a thought.
Received 40 Upvotes
Migration
A positive shut off, such as a zone valve, can be installed on either the supply or return. If there is something there stopping the flow thru that loop, you will not get migration. Even an air pocket will do it.
