boiler and boilermate piping diagram
New Member
I am looking for a good piping diagram for a weil-mclane boiler and an indirect water heater system.There will be 3 zones controlled with zone valves,plus the zone for the heater.Boiler will be a cg-4 with a standing pilot.(80%).Need one that shows expansion tank location,pressure reducer valve,any and all check valves,and any other accessories.Any suggestions where to find something on the internet would be greatly appreciated.Thank you.
indirect
http://www.amtrol.com/pdf/boilermateIO9040-586revC.pdf
Amtrol shows some suggested piping arrangements for their tank. You might be better using a dedicated circulator for the indirect tank so the DHW can be setup for priority over heating.
Pete
Pete
New Member
Thanks Radioconnection
Thanks so much for the reply.This is just what I was looking for.I can study it all weekend to get familiar with the job.It has to go in a closet and I am not sure I want to tackle it .Thanks again.
Received 40 Upvotes
Closet installation
Make sure you provide plenty of ventilation in that closet.
Radioconnection is absolutely right about the circulator for the indirect. Using a zone valve will increase the recovery time by a good bit.
