Taco pump bad???
Old 09-09-07, 10:34 AM
U
Taco pump bad???
Hello, I have a taco cartridge circulator pump. Is there any way to tell if this needs replacing.?? Other then very poor hot water psi all over. This has been a problem for sometime and I think I have check everything else....
Thanks for any help... Stan
Old 09-09-07, 11:04 AM
Who's Avatar
Who
Who is offline
Received 2 Upvotes on 1 Post
- cut the power to it and the boiler
- isolate it with the valves on either side of it
- pull it out and look at the impellor
- they aren't expensive
Old 09-09-07, 11:14 AM
Grady's Avatar
Received 40 Upvotes on 38 Posts
Domestic hot water?
If you are talking about low hot water pressure at the faucets, the circulator would have nothing to do with that.
