Wiring for Zone Control Valves
Old 09-13-07, 09:24 PM
P
Received 1 Upvote on 1 Post
I'm removing my boiler. The system has three zone control valves. I was careful to label everything.
But alas, I was not careful enough.
Each valve has a pair of yellow wires and a pair of red wires. If I knew what their internal hookup was I could wire them correctly to the other wires in the system. How can I find out what the wires go to internally?
See an image here:
http://pipsisiwah.home.bresnan.net/images/boiler7.jpg
Old 09-14-07, 06:57 AM
rbeck's Avatar
Received 66 Upvotes on 55 Posts
If you go to this web site and scroll to the wiring diagrams you will find the diagram you are looking for. You may not have a Burnham boiler but the zone valve wiring does not change
http://www.burnham.com/PDF/Series-2-IO.pdf
