R845A hook-up
Old 09-22-07, 05:44 AM
F
Question R845A hook-up
I just installed a new hydronic zone upstairs with separate taco circulator. I've followed the diagram for hooking up a honeywell R845A and can get circulator to work but boiler won't start. Any help would be appreciated.
Thanks
Old 09-22-07, 09:16 AM
Grady's Avatar
R845a
It would help to know what aquastat is on the boiler, if the boiler stays hot for domestic or is it cold start, & is the boiler gas or oil fired.
Old 09-23-07, 03:56 PM
F
The aquastat is a Honeywell L8151A. I hooked up according to schematic I got off of Honeywell website.
Old 09-23-07, 07:19 PM
Grady's Avatar
L8151a
Sorry, I can't find anything on that aquastat on Honeywell's site. Does this boiler stay hot for domestic hot water? Is the thermostat for the first zone 120 or 24 volts?
Old 09-24-07, 05:10 AM
F
R845a
Furnace stays hot for domestic hot water. I think the thermostat is 24 volt. Oil fired furnace.
thanks
Old 09-24-07, 04:30 PM
NJT's Avatar
NJT
NJT is offline
I found the 8151 here Grady:
customer.honeywell.com/request.cfm?form=60-2553
Triple a'stats confuse me ...
Old 09-24-07, 06:39 PM
Grady's Avatar
Wiring
Thanks Trooper. I've been having trouble with Honeywell's site for a few days now.
FilthyBill: If you used the wiring diagram on page 5 of the document to which Trooper linked, make sure water is actually circulating. It is quite common to have an air block after opening the system. Purge it well & try again. A tip off to not circulating is the boiler temp does not drop when the circulator runs or the return pipe does not get hot.
