"Banging Radiators"
Old 10-13-07, 07:20 PM
K
"Banging Radiators"
Hello. I'm new to this site. Here's my problem: The radiators in my house always bang during and shortly after the boiler is running. I bleed the radiators regurally and sometimes a small amount of air comes out of 2 of them. But other than that no air comes out at all. Any suggesstions? Thanks
Old 10-13-07, 07:30 PM
P
Steam or hot water?
Is the system steam or hot water?
Old 10-13-07, 08:19 PM
K
it's a hot water system
Old 10-14-07, 07:33 AM
P
Is the boiler staying at a steady pressure?
Is air getting into the system?
Could it be piping in the outside wall? Hot pipes meeting cold air can cause a bang.
Old 10-14-07, 08:06 AM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Noise
By the term "radiators" do you mean cast iron radiators or finned copper tube in a metal cabinet?
Old 10-14-07, 12:36 PM
K
They're Cast Iron Radiators. And When the boiler isn't running the pressure is about 20psi and after it runs for a cycle it climbs to about 24psi. I'm not sure how to determine if it is getting air in the system.
Old 10-14-07, 05:15 PM
Grady's Avatar
System Pressure
That's a lot of pressure for a house. I doubt the pressure has any thing to do with the noise but I suggest dropping the cold pressure to 12-15# & see if it makes a difference.
Old 10-14-07, 08:56 PM
K
how should i drop the pressure to 15? Should i just release water from the system?
Old 10-15-07, 03:25 PM
Grady's Avatar
Pressure
There should be one or more hose bibs on the boiler or near the circulator(s). Just open one & drain water into a bucket.
