anti freeze in a HWB sysrem
Old 10-28-07, 12:31 PM
I have a HWB system , 2 zone. Last year the system lost a zone valve and shutdown, sisnce it is a summer home I did not check it for a week and the baseboard pipe froze and burst. I would like to use antifreeze in the boiler and do not know which one to use? Can I use diluted pink or green auto anti?
Old 10-28-07, 12:52 PM
Who's Avatar
Who
Who is offline
Received 2 Upvotes on 1 Post
Don't use automotive antifreeze. Use a glycol specifically for hydronic heating usage.
Old 10-28-07, 06:12 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Anti-Freeze
Be sure to get the stuff made specificly for hot water heating systems. Once it is installed & the system runs for 15minutes or so, to get the water & anti-freeze well mixed, be sure to check the pH. There are compounds available to adjust the pH if needed. Failure to correct the pH can result in a corrosive mixture which can & will eat the copper.
Old 10-28-07, 07:38 PM
L
What should the PH be for a copper tube system?
Old 10-28-07, 08:07 PM
Grady's Avatar
pH
Here's a link to an article about anti-freeze & pH.
http://www.fueloilnews.com/uploads/f...7_feature5.asp
Personally, I think anything over 9.0 is too high. Just my opinion.
Old 10-28-07, 09:35 PM
Who's Avatar
Who
Who is offline
Is there any way you can reduce your risk of another freeze-up without antifreeze? It doesn't help your system any and you need to keep a much closer eye on the water quality.
