Motorized Valve for Zone Control
Old 11-04-07, 06:58 AM
I have a Honeywell v8043f1036 motorized valve on my hot water heating system. It is a three zone system . The one valve make a humming sound like it is still tring to close . It stops if I lightly tap it with my finger. Is this motorize valve failing? Or does the mechanizm not some clean or lube? thanks
Old 11-04-07, 07:44 AM
when the thermostat calls it energizes the motor in the valve head. this turns and opens the valve and at the same time it moves a lever that energizes the end switch for starting the heater. The motor stays energized the whole time the valve is opened. Once the temp is reached the power to the motor from the thermostat drops out and a spring pulls the valve closed.
If the motor is humming it could be on it's way out. you can buy and replace just the motor by removing one screw without having to replace the whole head.
How hot does it get
cheap and easy to do
Old 11-04-07, 09:30 AM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
or it could just be a vibration and nothing wrong...
Old 11-10-07, 08:58 AM
It gets pretty "HOT"
How hot does it get "I WILL BURN MY HAND IF I TRY TO TOUCH IT FOR A SHORT TIME.
WHERE DO I GET THE MOTOR?
Old 11-10-07, 08:57 PM
Grady's Avatar
Received 5 Votes on 5 Posts
Valve motor
Some plumbing supply houses carry them but not many, at least in my area. For an online source, you might want to try patriot-supply.com.
Old 11-11-07, 06:00 AM
A local sid harveys is where I get them
check this page that's about the most you should pay
http://www.hdsupply.ca/webapp/wcs/st...tegoryId=10881
https://www.hdsupply.ca/webapp/wcs/s...tegoryId=10398
Old 11-11-07, 06:33 AM
Grady had pointed you in the right direction for online
Old 11-11-07, 09:03 AM
rupert326's Avatar
Grainger and Home Depot sells them.
Old 11-11-07, 01:03 PM
Check eBay. There are often new heads and motors offered over there, at a fraction of what you will pay not being in the trades.
Pete
