Procedure for bleeding a FHW Zone
Old 11-07-07, 08:16 AM
H
I need the procedure for bleeding a zone on my forced hot water system. The circulator pump runs and there is no heat on either side of it. There is a bleed valve on the pipe for the zone.
Old 11-07-07, 05:49 PM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
Need lots more info ... pictures would be best. If you can take some and post them on www.photobucket.com and provide a link here, we can try to help.
If you feel no heat on either side of the circ, you may have more of a problem than just air, but until we can see the system it's hit or miss.
Old 11-07-07, 06:25 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
No heat
What's the pressure on the boiler?
