hydro zone not working
I have a hydro system ( heating and cooling) we use a burnham oil burner and have 5 zones one of the zones stopped working, i have replaced the circulator pump, i can hear the pump working but for some reason i don't thing water is circulating ( air handler doesn't turn on and pipes are not hot) i hve atempeted to bleed the system but still no luck, any ideias?
thanks
thanks
i have 1 circulator per zone ( it was working fine last year)
Received 41 Upvotes
Zone
Presuming you have separate check valves, external to the circulator, try opening the check for the troublesome zone. It is possible the valve is stuck. Sometimes a firm tap on the side with a hammer will free a stuck flow check.
CAUTION: These flow checks are usually cast iron. Don't wail on it. Just a good firm rap.
If my friend the hammer doesn't help, does the coil have a bleeder on it? Usually they do. Try bleeding from there.
Received 41 Upvotes
Pictures
We love pictures. They make it so much easier to explain how to do what to what. Shots of the boiler & nearby piping as well as the hot water coil in the air handler would be most helpful. You can post them on photobucket.com or similar site & provide a link here.
problem fixed
Well thank you for your help
