Biasi Thermic Valve and P/S piping project--done!
Here's some photos of my finished DIY Biasi boiler install, which was started last year... Over the summer I added a TV valve for boiler protection, and also added P/S piping for the heating system. The system is monitored by Tekmar 260 outdoor reset controller. The electric water heater is temporary and was used for hotwater in the past--I'm going to move it and store it for future use as needed. The P/S piping allows using a boiler minimum well under 150 degrees, since the TV valve always keeps the return at 140 degrees or higher.
So far it is working great. NOTE: this install was done under a building permit and inspected, and a modification of code was granted for the wood boiler emergency backup boiler.
Pete
http://i117.photobucket.com/albums/o.../PSpiping2.jpg
http://i117.photobucket.com/albums/o.../PSpiping3.jpg
http://i117.photobucket.com/albums/o...n/PSpiping.jpg
Pete
Received 40 Upvotes
Nice looking job, Pete. Zones color coded, nice clean solder joints, lots of valves, permitted, & inspected. Congratulations are in order.
Wish most "pros" would do such nice work. Just one question: What's the coil of orange tubing(?) on top of the boiler? Looks like it goes to the air scoop.
http://i117.photobucket.com/albums/o...all-switch.jpg
I also added Burham temp gauges on the boiler supply and return that are in this newer photo.
Pete
Received 40 Upvotes
Wow
Nice touch, the test station. Aren't you Mr. Nice Guy to the service tech? Of course we both know who the service tech is. :mask: And to think just over a year ago you were a virtual novice. You've done well, Grasshopper.
Received 40 Upvotes
Another Question
Was just looking at the pics again & didn't see a service switch on the boiler. Is there one that I didn't see? Around here, a tough inspector will bust you for not having one "within arm's reach while working on the burner".
You could pick on me for not having an 18" straight run before the Taco airscoop, or having the weighted flow on the suction side of the pump.
Pete
You said it Grady! I showed them to SWMBO, and even she was impressed! She walked out of the room mumbling something that sounded like " DIVE! DIVE! RUN SILENT! "
Seriously, I am seriously jealous...
