Burner question
Old 11-13-07, 03:38 PM
T
Burner question
I have an old Slant Fin boiler that I just replaced the burners. The old ones were pretty well shot, and on occasion, there would be a real mild "pop" resulting in a fire inside the burner. I assumed this was from the old burners being burned out. Now after replacing all the burners with the new ones, I'm still getting the fire inside a burner shortly after fire up.
Any thoughts?
Thanks much,
Todd
Old 11-13-07, 07:54 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Burners
Has anyone checked the gas pressure? Are you sure the correct orifices are installed?
Old 11-23-07, 01:46 PM
T
Thanks Grady,
Yes and yes! I throttled down the gas shut off valve a bit and it seems to help. Any other ideas?
Todd
Old 11-23-07, 05:10 PM
Grady's Avatar
Gas shut off valve
Something's not right. By throttling the shut off valve, you are reducing the amount of gas available to the burners. I suggest you contact a professional to set up the burners. You could be producing huge amounts of carbon monoxide.
