Zone valve end switch problem
My house has hydronic baseboard heating with 3 zones, and when the thermostat switches zone #2 on, the boiler does not fire up. However, when zone #1 switches on, the boiler fires up and zone #2 starts emitting heat.
The internet overlords tell me that this is because the end switch on the zone valve for zone #2 is faulty. Does this sound correct?
What kind of Zone Valves do you have?
Electric motor driven or heat motor type (TACO).
The electric motor types use microswitches which can be replaced ifyou are handy with electronics/electrical work. Otherwise you simply replace the power head and leave the valve alone.
Taco power heads have an open switch leaf-spring/contacts assembly that can fail due to heat damaging the plastic spacers..
Pete
Pete
Should be easy to change. Post the model number of the valve. Someone will probably be able to tell you how to do it, where to find parts, and give you a link to the PDF file on the Honeywell site for your valves.
