Differences between automotive and fuel oil filters??
Old 12-05-07, 01:41 PM
R
I've been wondering if a good automotive oil filter would substitute for a spin on oil filter (like the Garbar)? Same size threads? How many microns are the automotive filters? UL listing a consideration?
Pete
Old 12-05-07, 02:02 PM
Ed Imeduc's Avatar
Wink
Id say forget it. The filter cartridges for the fuel oil are a lot better . They use a wool felt element or a spun rayon fiber in them .
Old 12-05-07, 02:07 PM
O
Great Idea,,,
and I have thought about that too,,,,but I get distracted and,,,you know,,,now that you mention-it, I`m gonna find out!
Thanks Radioconnection.
Old 12-05-07, 06:06 PM
Grady's Avatar
Received 35 Votes on 33 Posts
Fuel Filters
I use Wix 33109 or NAPA 3109 filters all the time. They are not compatable with the Garber filter head. Pretty sure they are a 10 micron filter. The actual application is for Cummins diesels. I use a spin-on only for a "polishing" or secondary filter due to cost. For a primary, I like Sid Harvey's 265, the General 2A-700A or Unifilter 99. Do not like any Westwood filter due to too many air leak problems.
Old 12-05-07, 06:29 PM
Who's Avatar
Who
Who is offline
Received 1 Vote on 1 Post
Ed, did you just get busted on a bad guess for a response?
Old 12-05-07, 06:37 PM
R
Is the Garber the same type of filter used on the Tiger Loop? All of my filters are spin on types.
Pete
Old 12-05-07, 07:07 PM
A
I prefer the Garber over any other filter. The Garber does a much better job filtering the oil than any fiber filter I've seen. The extra cost is worth not having a breakdown half way through the year.
Old 12-05-07, 07:12 PM
NJT's Avatar
NJT
NJT is offline
Received 4 Votes on 3 Posts
I use Wix 33109 or NAPA 3109 filters all the time. They are not compatable with the Garber filter head. .
Grady, did you mean they ARE compatible ? or am I reading something wrong ? If they are compatible, I assume they will fit the Suntec heads with the built-in OSV also ?
Old 12-05-07, 07:23 PM
Grady's Avatar
Wix, NAPA, & Garber
The Wix & NAPA filters are NOT compatable with the Garber head. The Garber uses an O-ring where the others use a thicker rubber washer. If you try to use the washer, there's a strong possibility of a leak. I don't believe the Garber's O-ring will seal the center (inlet?) completely from the outer holes (outlet?) of the Wix & NAPA filters.
I have not yet run into the OSV/Filter combo, so I can't speak about them. The heads on which I use the Wix & NAPA filters originally were sold by Wix & Energy Kinetics.
Old 12-05-07, 08:19 PM
NJT's Avatar
NJT
NJT is offline
OK good... The Suntec uses the O-ring also, a big fat one. But the filter itself appears to be the same as the others I've seen. The O-ring slips over the nipple on the filter head before the can is screwed on.
So it seems that the Suntec and Garber are probably interchangeable. Haven't used the Garber yet though. I'm currently using a Westwood (no air leaks!) on the Suntec head, because it was free... and when I installed it, it did contact the O-ring the same way as the Suntec filter did, so I'm pretty sure that seals up fine.
I'm running the smaller General (25) ahead of the Suntec.
So you are saying that the reason the aren't compatible is because of the O-ring, and not the threads, right ?
Old 12-05-07, 08:29 PM
NJT's Avatar
NJT
NJT is offline
RadioConnection
Radio-meister, are you using the tiger loop with the filter ? I thought yours was the little R2/D2 like mine ?
Old 12-05-07, 08:30 PM
Grady's Avatar
O-ring/Threads
The O-ring is the biggest problem but I have seen some old Garbers with a different thread. These were probalbly 20+ years old.
Old 12-06-07, 03:00 AM
R
Mine has the filter below it. Integral unit.
