Installing a Taco 571-2 zone valve
Old 12-19-07, 06:16 AM
T
Hello,
I currently have 3 zones being serviced by 3 Taco 571-2 zone valves on a Burnham oil furnace. I plan to install an indirect water heater to the system. When I add another zone valve, will I have to install another transformer or will the existing one handle all 4 valves?
Old 12-20-07, 06:49 PM
Grady's Avatar
Received 23 Votes on 21 Posts
Zone Valve
You don't want to use a zone valve for an indirect. You should use a dedicated circulator. Zone valves restrict the flow too much.
Old 12-21-07, 08:31 AM
rbeck's Avatar
Received 5 Votes on 4 Posts
I agree with Grady with the exception if you get a full port zone valve it would be OK. These are hard to find in most supply Houses. If you could get one you would have to add a second transformer or replace the existing transformer with aarger VA transformer. The best way is with a circulator and proper sized piping.
