Boiler heater knocking pipes
Old 12-19-07, 05:51 PM
I have a boiler with radiators for heat. Lately we have been getting loud knocks - it seems like its mostly when the heat goes on. Any ideas on what the problem might be?
Old 12-19-07, 05:53 PM
Who's Avatar
Who
Who is offline
steam or hot water?
Old 12-19-07, 05:55 PM
its hot water heat
Old 12-19-07, 06:44 PM
Who's Avatar
Who
Who is offline
Cast iron rads, fintube baseboards? What kind of radiators do you have? Are you using a programmable setback t-stat now that you weren't before?
"This forum requires that you wait 180 seconds between posts. Please try again in 77 seconds."
Old 12-19-07, 06:57 PM
We have cast iron radiators and we haven't changed anything with the programming. And if it makes any difference the knocking is getting progressively worse.
Old 12-19-07, 07:08 PM
Who's Avatar
Who
Who is offline
Can you tell where the bang is coming from?
Old 12-19-07, 08:41 PM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
There is a pressure/temp gauge on the boiler, can you tell us the readings ? Is the pressure gauge steady when it 'knocks' ? or does it jump ?
Old 12-20-07, 02:24 PM
It sounds like the knock is coming from the radiators, but its so random that I'm not really sure.
I'll get the readings on the pressure/temp gauge shortly, but I'm not sure if it jumps when it knocks because of the same reason above.
