Honeywell FM450 reducing valve blunder!
Old 12-22-07, 12:49 PM
R
Okay, I opened mine up to service it (the fast fill lever was sticking.) In the process I think I lost a part
Uscrewing the cone, I have the outer collar, the spring inside the collar, and a stepped plastic washer. When I put it back together the pressure setting screw does not reach far enough to activate the valve. Is there a short rod that goes inside the spring, between the valve and lead screw? There's no IPB on the Honeywell website. I've swept the cellar floor five times and I am finding nothing that fits
http://customer.honeywell.com/honeyw...nfo.aspx/FM450
Old 12-22-07, 01:22 PM
Grady's Avatar
Received 23 Votes on 21 Posts
Reducing Valve
No chance the washer is in upside down?
Old 12-22-07, 01:43 PM
R
I don't know what the plastic washer is or was for? It seemed to fit inside of the collar, but it doesn't do anything that I can see. So, it might belong to something else?? I found a lot of treasures when I swept under boiler!!
BUT!! I did find a stepped brass washer with a cone indent that matches up purrrfecctly with the pressure screw end... She seems to be all better now. I can fast fill, and adjust for the correct automatic pressure.
Pete
Old 12-22-07, 02:05 PM
Grady's Avatar
Treasures
Yeah, I bet you found a whole host of stuff.
Between you & Jeff, I don't know.
Anyhow, glad you got it put back together & it's working right.
Old 12-22-07, 02:22 PM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
I usually find only mouse skeletons...
Old 12-22-07, 09:14 PM
boilersrus's Avatar
I usually find better stuff wedged between the dryer and the washing machine!
Charlie
