furnace vs. boiler
I am in the planning stages of replacing an older furnace in my 3 story home. Right now it is an oil-fired furnace heating cast iron radiators.
Is there any advantage to using a boiler over a furnace? And how about whether to switch to gas vs. oil?
A boiler is what you have. A boiler heats water. A furnace heats air. It is all in the terminology.
About oil vs. gas, it depends on the local price. In my area, oil is much more expensive than gas.
- can heat people without moving air (which cools people)
- more energy efficient to transport hot water than hot air
- easier to control and zone water
- can use the boiler to heat domestic water as well
Furnace Advantages
- if it leaks, it only leaks air
- no water inside to freeze if the power fails
- can be cheaper
- allows use of modulating condensing boilers
- no tank (which can create insurance issues)
- easier for annual cleaning
- can use for BBQ, stove, dryer...
Fuel Oil Advantages
- can also be cheaper depending on market
- no gas line interruption risk
- can have more warning before CO posioning due to smoke
- natural gas reserves will run out before oil goes dry
