Bleeding Riello 40 Series F3
Old 01-26-08, 12:49 PM
I have a hot water baseboard boiler, it is a riello 40-f3 I am attempting to bleed the air out of the fuel line - not very successfully - I attempted to bleed it using what I thought was the bleeder port ( a large hex head with a smaller slotted piece in the middle of it ) air did seep out and i got a bit of oil coming through but when I hit the reset button it does the norm - shut off after approx 20sec
any help?
Thanks
Old 01-26-08, 01:51 PM
NJT's Avatar
NJT
NJT is offline
Received 2 Votes on 2 Posts
Oh boy ... that sounds more like the pump pressure adjustment to me ...
unless you have a gauge that you can adjust the pump pressure with, and I don't guess you do... it's time to call a service tech.
Tell him what you did ... don't make him guess ...
Old 01-26-08, 02:18 PM
Overhead oil lines? One or two pipes???
Is it going through the prepurge, and going out when it
doesn't prove ignition?? Could be a bad control module
or connection, bad cadcell, bad ignition transformer, etc. Clogged filter???
Old 01-26-08, 02:32 PM
NJT's Avatar
NJT
NJT is offline
I'm not sure I made a clear statement:
what I was trying to say is that I believe Tre mistakenly removed the screw that is intended to adjust pump pressure and should not be touched, instead of the bleeder port !
So, now the pump pressure is probably all outta whack ...
in addition to the reason he tried to bleed it in the first place.
