Air Vents On a 2 Pipe Steam Radiator System?
Old 02-28-08, 03:49 PM
W
I have a 2 pipe system for steam heat using radiators. I have read on a 2 pipe system air vents on the radiators are not needed. Is this accurate information? I do not have any steam traps on the return part of the radiatpors.
Old 05-22-13, 11:26 AM
B
Vents are not needed on a two pipe system.
Old 05-22-13, 01:18 PM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
Really? not needed? Can you please explain why not?
Old 05-27-13, 07:28 AM
rbeck's Avatar
Received 5 Votes on 4 Posts
He probably meant radiator vents are not needed. You always need vents. On a two pipe system the vents are after the last radiator supply on at the end of mains or dry returns. If there is a condensate tank the tank is vented.
