aquatsat L8148E
Old 03-01-08, 09:38 AM
N
aquatsat L8148E
I have a 3 zone gas heating system with an aquastat L8148E. When all 3 zones call for heat and the water temp reaches 180 deg the gas burner keeps cycleing on and off. If I tap the high limit dial switch with a screw driver the burner will stop cycleing on and off and will work normally for a day or two. Should I replace the aquastat ?.
Old 03-01-08, 10:03 AM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
You checked all connections for tightness, yes ?
It does sound as though the a'stat might be 'flaky' though.
If all connections are clean and tight, then I'd say yes, replace it, it will only get worse.
