determining the proper pressure for an expansion tank
Old 03-21-08, 03:39 PM
Member In Good Standing
My hot water heat system recently was more than doubled in the number of zones and length of pipe. The expansion tank needs to go from a 15 to a 30. Currently with the 15 tank the water pressure is about 12-15 # when the system is cold. It rises to 22-30# when hot, which is the reason for the larger tank. What is the proper pressure to charge the new tank before installing? I've heard 12 and also 15. The highest baseboard radiator is about 15 feet above the center of the boiler. Don't know if it matters but the house is at 8500' elevation.
Old 03-21-08, 03:54 PM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
The tank should be pre-charged to the same pressure as the system when cold. Anywhere from 12-15 is fine ... not super-critical. If you start with 15, and the tank will typically lose 1 PSI per year, then you won't have to mess with it but every 3 years or so.
If there is no isolation valve between the boiler and the tank, install one at this time unless your local codes dis-allow it. This will make later tank servicing much easier.
