American Standard cast iron boiler
Hello:
I have an American Standard cast iron hot water boiler in my basement.
For the past 30 years I have been heating my house with it by burning wood .
The model name is : American Severn .
Some guys, I can no longer find, installed it for me. It has
run flawlessly all these years .
Originally it might have been coal converted to gas and then to wood .That's a guess based on the large fire box .
Anyway ,my homeowners ins. will no longer insure me unless It is moved out . Since it is such a wonderful piece of equipment ,I want to make it my outdoor woodburner .Any old specs that will guide me taking it apart and reassembling?
Advice much appreciated .
The unit sits flat on a concrete floor .There are five units held together by four 3/4''threaded rods . Two on each side .
The front has two doors .One is the fire box door .It's on the bottom . The one on top is a little smaller . It further heats the water with heat from the top of the fire fox .
Sorry , I can't answer your question about dry leg /wet leg .I don't know what is meant by the term .Hope this helps .If not ,I could try sending pics .Thank you .
Received 38 Upvotes
We LOVE pictures!
You need to upload the pictures to a photo hosting site and then post the URLs here.
I'll bet that thing weighs a ton...literally. Moving it might be quite the chore and especially if it has to go through a small doorway or up stairs.
It does come apart but taking it apart may also cause its destruction.
Anytime you take a sectional cast iron boiler apart you must install new push nipples or the boiler will leak when you put it back together. I highly doubt the push nipples are available anymore to re-assemble. If you can determine the size and depth you may be able to find something to work but you won't be privy to that information until you tear it apart.
I have a manual
for that boiler that I got off ebay. If you are interested, I'll try to scan it, it's about 20 pages or so.
What didn't your insurance company like? I'm in the process of refurbishing the Severn in my house as a backup heat source in case of power failure. It hasn't been used for a few years and the sealing between the sections is failing.
Severn B1
capetom,
My buddy has a Severn B1 that's been out of service for several years - got flooded and partially parted out. We took the nuts off of the external assembly bolts but the sections don't seem to want to come apart. I'm thinking there's more hardware somewhere... The manual might be generic enough to be of use to us. What's your price? BTW - the furnace resides in N.E. Pennsylvania in case there are any parts takers. Not sure of overall condition - we're prepared to hack and plasma cut if necessary.
Thanks.
Thanks.
I am planning to set this unit up as a remote boiler in a new shed near my farm house. I would really appreciate a copy of that manual, if it is still available, or insight as to where I can find more information. Thanks for all the insight. ***********
Last edited by GregH; 09-17-08 at 07:50 PM. Reason: Email address not permitted in posts.
How did you seperate the sections of the boiler? I loosened the 4 long bolts, 2 on the top and 2 on the bottom. Did you start on the front section or the back? You mentioned an air chisel, is that all it took?
