tigerloop
tigerloop
I needed to have my line blown out for my oil burner although he didnt say what was cloggin it, the technician told me to put a tiger loop on . I looked it up online so now I have an idea of what it is. My question is this. How involved is this tigerloop to install yourself?
Received 39 Upvotes
Clogged line
Simply installing a Tigerloop will not solve the problem. I presume you are drawing fuel from the bottom of the tank. If this is the case, you need to install a line inserted into the top of the tank. You should also replace the existing line feeding the burner. Here is a link to information about the Tigerloop. There is a link in there to a piping diagram.
http://www.westwoodproducts.com/tige...igerloop_ultra
