Sundstrand pump ID and X-reference.
Old 04-23-08, 10:29 AM
Hello all
I have an old Sundstrand pump that needs
to be replaced. The number on it is S1RB-201.
Could anyone cross it to a Suntec # ?
Thanks.
John
Old 04-23-08, 06:12 PM
Grady's Avatar
Received 32 Votes on 30 Posts
Sunstrand
Is that a fuel pump or a circulator? Some more details & pics would help.
Old 04-24-08, 04:54 AM
It's a fuel oil pump for an oil burner. I can't seem
to find any info on that perticular part #. It looks
similar to this.
John
Old 04-24-08, 07:12 PM
Grady's Avatar
Fuel Pump
The one you have pictured is a J or H pump. In order to suggest a replacement I need to know speed, rotation, firing rate, firing pressure, & mounting method (hub or flange).
Old 10-26-08, 11:20 PM
R
sunstrand pump and x -reference
Hi, I have the identical sunstrand pump on my oil burner and do not know how to take the strainer out to clean it. I can drain the pump and reprime it OK but I just cannot figure out where the strainer is. Do I have to take out all the bolts on the end of the pump? Where on the pump could you put a pressure guage to see how well the pump is working?
Thanks, Rich
Old 10-27-08, 08:35 AM
O
J-Pump
To access the strainer the 8 cover bolts are removed. The strainer being a basket that pulls out.
For the gauge pressure port it is on the side of the pump next to the outlet port. The side of the pump being the same end as the cover. It is typically a 1/8" NPT thread.
In the picture posted above it looks like there is a bleeder in the pressure port.
Al.
Old 10-27-08, 03:23 PM
Grady's Avatar
Checking Pressure
I usually just dead end the copper nozzle tube into a gauge.
