One pipe steam balancing
Old 04-23-08, 09:32 AM
Hello
It seems that everyone I ask about balancing
a one pipe steam system gives a different answer.
Is there a FAQ or How-To somewhere that explains
this ?
Thanks
John
Old 04-23-08, 09:38 AM
F
Try www.heatinghelp.com for a FAQ.
As for balancing...it kind of depends on what you mean by balancing. If you mean to regulate the amount of heat from different radiators, that is not possible. However, if you mean to "balance" all radiators to come to heat at the same time then the only answer is to install adjustable air vents and use a larger vent opening on the "slow" radiators and a smaller vent opening on the "fast" radiators.
Old 04-23-08, 05:23 PM
Grady's Avatar
Received 39 Upvotes on 37 Posts
Steam System
While at the site Furd mentioned, I suggest you visit their bookstore. Dan Holohan, the owner of the site, has written some VERY good books on steam systems. This one in particular should be a "must have" for every homeowner with steam heat. http://www.heatinghelp.com/shopcart/...category=2-109
Old 04-23-08, 07:34 PM
rbeck's Avatar
Received 61 Upvotes on 51 Posts
Smaller radiators vent slower than larger radiators. To properly balance the system you must have good operating main line vents. The idea is vent the mains rapidly and the rad vents need only vent the rads and vertical piping.
Old 04-24-08, 03:58 AM
Thanks Guys !! Good info !
