How to zone valve/pump question
Old 07-16-08, 08:31 AM
I currently have a gas fired hot water high temp system. Four zones, using zone valves (Argo zone controler) and one main pump on the boiler. I wnat to add a few low temp zones for radiant heat. My question is how would I zone out the radiant side. Do I need to install a second pump just for the radiant ? How would I control the pump ? Any help would be great.
Old 07-16-08, 12:14 PM
plumbingods's Avatar
I am not fully trained in radiant in floor heating, but I am pretty sure you do need a separate circulator, because with radiant, you need to control the flow and water temperature differently than standard baseboard. That much I do know.
I am sure one of the other heat techs will be dropping in and will hopefully have more info for you. (and me)
Old 07-16-08, 06:27 PM
Thanks for taking the time and responding to my question. I am pretty sure I need a second circ. pump for the radiant side. I am just not sure how to turn on two pumps and fire the boiler. I also know I need a mixing valve to get water to radiant temp. Right now when thermostat calls for heat the zone valve opens, the flue opens and the boiler fires.
Thanks
Old 07-18-08, 06:31 AM
Who's Avatar
Who
Who is offline
A very simple method would be to use a Taco RMB (radiant mixing block). It's a small all in one unit, that has a circulator for the actual radiant loop(s), an injection circulator to mix the water temperature down to what it needs to be as well as a controller to control the water temps based on a t-stat and an outdoor temperature sensor. They are in the thousand dollar range at your local supply house but form an excellent easy to pipe solution.
Old 07-18-08, 07:39 AM
A second vote for the Taco RMB. More up front cost, but a breeze to pipe, wire, and control that definitely makes up for the higher initial cost. Much less labor and design involved.
Old 07-18-08, 06:58 PM
Thanks for responding to my question. I will look into the Taco RMB. Hopefully I can figure out how to wire so the boiler main pump turns on and the boiler fires when the Radiant side calls for heat.
Thanks again
Old 07-18-08, 07:28 PM
Start here:
http://taco-hvac.com/en/products.htm...t_category=120
Wiring guides, application guides, and even a couple videos!
Old 07-19-08, 07:59 AM
Thanks for the info I'll check the link out
