Aquastat not working in auto
  #41
Old 10-15-08, 08:58 PM
squidster's Avatar
Whoaaa, hold on.
I ohmed the terminals on the a-stat, not the wires I disconnected. My bad, I misunderstood what you were asking for. Man, I am tired.
I just ohmed the wires (disconnected from the a-stat) and ..infinity, no continuity, open circuit. Must have good end switches on the Z-valves. whew....
  #42
Old 10-16-08, 04:58 PM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
Tell me how many, and what brand/model of zone valves you have.
If you've got the 3 wire Taco valves, my plan of using the zone valve transformer won't work ... (I guess I was assuming (again!) that you had 4 wire valves with isolated end switches... but I bet you don't ... ) and I think that's why the circulator continued to run ... you are going to need a separate external transformer to power that a'stat. Either that, or replace it ...
  #43
Old 10-16-08, 06:01 PM
squidster's Avatar
White Rogers Zone-A-Flow valves. Two wire TT's. There are three other wires that jump between each valve.
  #44
Old 10-16-08, 07:34 PM
NJT's Avatar
NJT
NJT is offline
I don't think the plan will work with those valves either ...
I'd mount another 24VAC transformer and wire it to B3 and W as above...
