Problem with heatmaker boiler
Old 10-11-08, 05:54 AM
I have an older heatmaker Mark II boiler that has been working great all these years.
Now on firing it up, the water temp won't go over 170 degrees and the boiler won't cut out and stays constantly running.
I believe its supposed to go to 210 degrees before it cuts out.
Any ideas?
Old 10-11-08, 06:09 AM
Grady's Avatar
Received 40 Upvotes on 38 Posts
210º
It is a rare instance where you need 210º water to heat the house. In fact, even 170º is often more than is needed. If the thermostat is calling for heat, the boiler is going to run a while.
Old 10-11-08, 07:00 AM
210 degrees
Yes its calling for heat but this boiler always gets up to the cutout temp quickly and then hot water pumps till the temp goes down and then it fires up again. It won't get over 170
and its not cold out yet.
