draining and bleeding my burnham gas furnace
Received 0 Votes
I have a burnham gas furnace PXG2005 A WNI searal # and want to know how to drain and bleed this system ?
This is a hot-water boiler?
There must be a drain valve at a low point of the system. Open that valve and open a vent on one of the highest radiator/convectors.
When you say "bleed," are you wanting to bleed the air?
Why are you wanting to drain the system? Normally not necessary unless the system needs to be opened for repair.
Doug
Doug
Fresh water has a ton of oxygen in solution ... when you heat that water, all that oxygen starts to get driven out of the water.
Many of the components in the system are ferrous metals. Water + Oxygen + Iron = RUST
If you have to open the system for service, that's one thing, but it happens that sometimes people are under the misconception that it's a GOOD thing to change the water. They're gonna flush all that nasty rusty water out and put in some nice fresh water. But, once they do that, a whole new batch of rust forms, until all the oxygen is driven out and the water becomes inert.
It's always best to drain as little as possible when you do have to drain.
