converting steam system
I am converting some steam radiators into hot water.
I have 3 radiators hanging horizontally in the basement ceiling.
They have 2 pipes going into them on one side at the same level, one being the steam and the other the return.
The other side has 2 pluged holes.
How do I pipe these radiators so that they work best?
Do I use the 2 holes currently on the one side as a supply and return, remuve a plug from the other side and insteall a bleeder valve or...
do Ipipe a supply into the hole closest to the boiler and a return diagonally on the other side where its currently plugged and if I do it like this, where does the bleeder valve go?
Any comments/suggestions are very much appreciated.
Received 39 Upvotes
Horizontal Radiators
You need to pipe into one side at the bottom & out the other at the top. Regardless of how you pipe, getting the air out of a horizontally mounted radiator is going to be difficult. Also, some radiators are made specificly for steam.
