Grundfos circulator "Setting" question..
Have a question on the settings on my Grundfos circulators. They can be set as Low/Medium/High as far as circ speed/flow. Two questions. First, as to comfort. Does the higher circulator flow mean that the hot water baseboard is putting out slightly more heat? And second, if the water flow circ is increased, am I using more oil? I guess the default setting is in the medium position. I am curious about the Low and High settings....Thanks, Bill (Sorry if I asked this question before, I don't recall a reply.
The speed of the pump should be such that flow velocity is between 2-4 Feet Per Second. This will be fast enough to remove trapped air bubbles, and not so fast that you will hear the water running, or scour the inside of the pipes until they leak.
At that flow rate, in a properly designed system, the difference in temperature between the supply and return will be around 20 degrees F ... a slower pump speed will INCREASE that difference, and a faster speed will DECREASE it. You could put thermometers on both the supply and return ... or,
just set them on medium and enjoy the warmth!
..thanks NJ! Set to medium. By the way, With the OR, the boiler temp has yet to come up over 148-150F even with the outdoor temps as low as 18-20F, and we are toasty. I am beginning to wonder when I will see a higher boiler temp...hope I don't! Its early yet so far I calculate I have saved about a 100 gallons of oil.... Thanks, Bill
