where to place backflow preventer
Old 11-20-08, 06:09 PM
R
Hi,
I'm going to put a backflow preventer on my boiler. I wanted to make sure it went in at the right spot.
I was going to put it just upstream of the gate valve (which is upstream of the sequence: filler valve, bleeder, PRV, and expansion tank).
Is this right?
Thanks for any info.
Old 11-20-08, 06:46 PM
Grady's Avatar
Received 23 Votes on 21 Posts
Backflow Preventer
Put it between the gate valve & the pressure reducing (feed) valve.
Old 11-21-08, 05:38 AM
R
Don't forgot to make sure the arrow stamped on the backflow preventer is pointing towards the boiler.
Old 11-21-08, 08:30 PM
R
Just wanted to make sure I got it: Grady's talking about "water feed pressure regulator" and not the whole-house pressure reducing valve that's right next to the main water shutoff, right?
So, I should put the backflow preventer just a bit closer to the boiler than the gate.
I will look for the flow direction arrow.
Thanks for the help!
Old 11-21-08, 08:36 PM
Grady's Avatar
Backflow preventer
Yes, I was referring to the water feed valve for the boiler not the whole house pressure reducing valve. The backflow preventer goes between the shut off valve (gate valve?) & the "water feed pressure regulator" with the arrow pointing toward the "water feed pressure regulator".
Old 11-23-08, 10:42 AM
R
Okay. Thanks Grady. I figure I should ask the dumb question (instead of doing the dumb thing).
I didn't want to have a moment like in that Saturday Night Live skit where they're trying to figure out what "you can't add too much water to the nuclear reactor" means...
