main line vent
Old 11-20-08, 08:29 PM
T
main line vent
As the steam travels across the main line, I can feel it moving. By the time i get to the end of main, the radiators connected to the 1st riser is already hot and the one furthest away is just about to receive steam. Does this sound like maybe the main line vent is not working properly?
I read that if the main line vent is working properly, the steam should travel fairly quickly across to the end and rise up together on all the risers.
Thanks!
Old 11-21-08, 03:17 PM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
I'm 'steam stupid', but I believe you are correct ... it sounds like that main vent is either slow, or perhaps not working ... do you hear it hiss ? then stop when the steam hits it ?
Old 11-21-08, 03:43 PM
T
I do not hear any hissing. The vent does get hot after steam travel across it.
Is replacing the main line vent the same as replacing the air vent? Like does it just screw in?
Thanks!
Old 11-21-08, 07:11 PM
rbeck's Avatar
Received 5 Votes on 4 Posts
Make sure there is no steam pressure on the system and remove the main line steam vent. Does the steam get there faster? If so replace the vent and maybe do a dual vent.
See this link
Steam FAQ
See the venting questions near the bottom of the page
Old 11-21-08, 07:17 PM
T
Do i just unscrew the main line vent off just like the air vent on the radiator? Or do i need a wrench and/or special technique to get it off without doing any other damage to the system?
