gas valve hot water system help needed
Old 11-24-08, 04:00 PM
T
Dunkirk raditator corp system.
gas valve was needed replaced. part number is VR8440M 3022
I had bought a gas valve not realizing the one I bought was for LP gas. It says Dual valve combination gas control.
Can I convert this to natural gas. this part number i s
VR8440A 6036.
If so what needs done.
Old 11-24-08, 06:27 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Vr8440a 6036
When I checked Honeywell's site, that number came back as obsolete.
Old 11-26-08, 07:23 AM
T
gas valve
what I cross- referenced my old valve number vr8440m-3022 it came up with about 40 different valves, the one I bought is in the list, but It sales LP only on the side of the valve.
I can get the pilot light to come on with the boiler, but not the burners?
can it be something else ??
Old 11-26-08, 05:36 PM
Grady's Avatar
LP Valve
If it is labeled as LP Only, it is not convertable. You probably don't have enough pressure to open the valve. Some LP valves require a minimum of about 9" W.C. to open. Your natural gas system is likely around 5 or 6.
To make a long story short, you need a new valve.
Old 11-27-08, 09:32 AM
T
valve
what does it mean when the valve is dual valve combination gas control ??
It also states in directions to change the adjustment screw from LP to natural.
Both these part numbers show listed as replacement parts for each other ?
here is a copy of a list I have.
VLV42A-602 VR8440A2076 VR8440M3648 UR8440A2076 VR8304M 3509 VR8304M3509 VR8440A 2068 VR8440A2068 VR8440M 1018 VR8440M1018 VR8440M 1034 VR8440M1034 VR8440M 3006 VR8440M3006 VR8440M 3022 VR8440M3022 VR8440M 3030 VR8440M3030 VR8440M 3048 VR8440M3048 VR8440M 3055 VR8440M3055 VR844A 1036 VR844A1036 VR844M 1022 VR844M1022 VR844M 1048 VR844M1048 VR844M 1071 VR844M1071 VR844M 1097 VR844M1097 VR844M 1105 VR844M1105 VR844M 1113 VR844M1113 VR844M 1121 VR844M1121 VR844M 1147 VR844M1147 VR844M 1154 VR844M1154 VR8304M 3103 VR8304M3103 VR8304M 3111 VR8304M3111 VR8304M 3129 VR8304M3129 VR8304M 3152 VR8304M3152 VR8304M 3160 VR8304M3160 VR8304M 3178 VR8304M3178 VR8304M 3186 VR8304M3186 VR8304M 3517 VR8304M3517 VR8304H4503 VR8304M4507 A15691-600R VLV49A-600R VR8345M4302 VR830MH3505 VR8440A3025 VR8440A6028 VR8440A6036 VR8304M3509 SP10963B CARVR8304M3509
Old 11-27-08, 09:39 AM
Grady's Avatar
Dual Valve
The "Dual Valve" means there is a double shut off inside the valve. Some older valves & even newer ones intended just for natural gas are just single. All LP gas valves are dual.
Old 11-27-08, 11:51 AM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
I only came up with one 'functional replacement' for your old valve from Honeywell's site ... where did that list come from ?
This is the one they call a 'functional replacement':
VR8304M 3509
Old 11-27-08, 07:18 PM
T
list
I got it from an item whom a seller had on ebay. The seller was some hvac supplier.
The list has the number VR8304M 3509 you said would work, with that, why wouldnt any of the othe numbers listed work ?
Old 11-28-08, 04:18 PM
Grady's Avatar
Gas Valve
Some of the others may work but the only one Honeywell lists on their web site as a replacement for your original valve is the VR8304M-3509.
Old 11-28-08, 05:42 PM
NJT's Avatar
NJT
NJT is offline
Who knows where that list came from ? the ebay dude mighta made it up himself ... and you might not have gotten the directions that go with that valve ... could be all sorts of scenario ...
or... maybe that's not the list of parts that it replaces, but rather a list of 'keywords' so that his items come up in everybody's search, no matter which valve they're searching for ... it's a common 'trick' ...
