white rodgers gas valve replacement
Received 0 Votes
i have a white rodgers gas valve Model 25G53 Type 406. What can I replace this with, apparently it is obsolete.
Received 0 Votes
"White-Rodgers has no suggested replacement for this item. You must contact the manufacturer of the equipment it was used on for a suggested replacement or retrofit.
You must contact the manufacturer of the equipment it was used on for a suggested replacement or retrofit."
Looks like you have some retrofitting/gas train rebuilding to do. If the old appliance is worth it, look into a universal gas valve, ignitor, module perhaps.
Then most any gas valve of that type, Honeywell, White-Rogers, etc., should work if the face-to-face dimensions are the same and the pipe-size connections are the same. Hopefully, there is one or more unions to facilitate valve removal and replacement.
Use pipe dope on the connections. I would replace the thermocouple while you're at it.
By the way, why are you replacing the valve?
Doug
Received 0 Votes
Its fixed
Guess I overreacted with the whole gas valve thingy. I did some further testing and determined that it was just the thermocouple. Sometimes I can be such a ditz. Anywho, thanks for all you advise.
Previous Thread
Next Thread
