no hot water
Old 01-24-09, 07:33 AM
R
no hot water
My boiler runs and heats normally. I have initial hot water then it rapidly goes away. My mixing valve seems to be operable. Is there a way to test the aquastat and could this be the problem?
Old 01-24-09, 10:04 AM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
Smack that drum and tell us a little more about your system.
Is it OK to assume that you are talking about the DOMESTIC hot water in your home that is produced from a coil in your heating boiler?
If so, those coils crud up over time with minerals from the water system... flow through them slows to a trickle, and of course the hot water goes away...
They CAN be boiled out with an acid solution, but this is NOT for a homeowner to perform...
Guessing, based on given info.
