pilot light
Old 01-28-09, 07:19 PM
pilot light
Just purchased a property with furnace intact but probably not in use for approx. two years. At first it took quite some time to get the pilot to light at all,then after it lit it would not stay on once releasing the red button. Changed the thermo coupling but still the pilot light goes out as soon as the button is released. What could be the problem
Old 01-29-09, 03:52 PM
HVAC Mech.'s Avatar
Could be a dirty pilot not impinging on the t-couple properly, or a bad pilot safety valve magnet/solenoid coil. Simple repair if you call a gasman.
Tom Beer 4U2
Old 01-29-09, 05:42 PM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
You are holding that button long enough for the thermocouple to get hot, correct?
Old 02-02-09, 03:58 PM
sounds like your gas valve
Old 02-02-09, 05:49 PM
Received 7 Votes on 7 Posts
A gas pilot only needs two things to stay lit. A good thermocouple that is in the hot pilot flame, and a good fuel valve.
Either one can be replaced by a proficient DIYer. Otherwise, call a pro for help.
Doug
