Air shutter question
Old 02-01-09, 07:52 AM
daswede's Avatar
My new Peerless M1-o4 gas water boiler does not have the adjustable air shutters like my old burner.
are newer boilers no longer adjustable?
Thanks
Old 02-01-09, 11:57 AM
F
Received 36 Votes on 28 Posts
If your boiler has an induced draft fan (exhaust gas blower) then you likely do not have any primary air shutters on the individual burners.
Quite simply, the entire boiler is designed for a specific airflow through the burners, combustion chamber(s) and draft fan. This is also why changing the firing rate is rarely able to be done in the field.
Old 02-01-09, 01:12 PM
daswede's Avatar
Thanks furd. Boiler is as you described
Old 02-01-09, 03:38 PM
NJT's Avatar
NJT
NJT is offline
Received 3 Votes on 2 Posts
I don't see an induced draft fan in that boiler... I think it's atmospheric... the install manual didn't say anything about combustion adjustments, other than to check and adjust the gas pressure.
Old 02-01-09, 04:27 PM
daswede's Avatar
The flue vent pipe has a damper in it. It is electrically operated when the burners come on.
I also, didn't see any mention of adjustments,other than calling a qualified person for service.
The boiler is pretty straight forward,and in looking it over i noticed that it didn't have any air shutters like my old 40 yr. boiler,and thats what made me wonder.
Old 02-01-09, 05:32 PM
NJT's Avatar
NJT
NJT is offline
Right, but that damper is not the same thing as an induced draft fan. What furd was talking about was an actual blower that moves air through the combustion area.
Old 02-01-09, 06:01 PM
daswede's Avatar
And thanks to you NJ Trooper
Old 02-02-09, 08:44 AM
rbeck's Avatar
Received 5 Votes on 4 Posts
Should not need air shutters on atmospheric burners. The velocity of the gas coming through an office out of a manifold with the proper manifold pressure, sets up a venturi to pull in the proper amount of primary air. If the air fuel mix is off it is due to improper manifold pressure.
By the way the secondary air is controlled by the draft hood, that is why we should never alter a draft hood.
